Dumb no starty/stumble question
Andy_Mac
So car had a bit of an issue today. Went to use it yesterday after being out of town for a few weeks and found the battery was flat so chucked it on the trickle charger for 24hrs which was sweet.
Then went to drive it today. Started as normal and moved it to the other side of the drive then left it idling for a few mins. Whilst I wasn't near it it decided to stall and wouldn't start again. Plugged the computer in, no DTC's. Sometimes it'd turn over like it does when doing a comp check with no intention of starting and other times it'd try start, run like death for half a second then stall again. Remembered someone saying try cranking it with the throttle wide open if its potentially flooded which seemed to work, coughed a few times then was sweet again. Went and filled it up and hasn't happened since.
Car was left with less than a quarter a of tank that was probably 3-4weeks old the last time I drove it. Does that sound like it could just be a case of bad/old fuel or something more sinister.
