2l vs 3l displacement and $$$ required
Heres 2 examples making similar power.
So the 2l has avcs, extensive headwork, oversized valves, big cams, 14mm studs, gtx3582 .82, sinco manifolds. Not sure if block was closed or sleeved. Forged internals.
29psi on e85
The 3l/ez30r has avcs/avls, only valve springs, murch holset hx5#, sinco manifolds. Stock block not sleeved or closed. Forged internals.
20psi on 98
23psi on e30
Bang for buck the 3l eats the 2l.
Pic to follow when I find a new host.
Complete side observation but the graph does kinda take a giant S*** on the "big turbos have bad driveability" argument; 200wkw (assume that's what the axis is?) at 4750rpm from the GTX3582 on a 2L; see if you can find me a VF turbo that makes that.
Add e85 and see what happens? Bet it drives nothing like a vf where you actually drive a vf. I know I drove more in the 3-5.5k region than the 4.7-8k region with the vf stuff I had. Difference would be nippy as opposed to hold on mafuker.
