Phone up Znoelli direct and get a price off them. Shouldnt cost you much extra to get the S6 or S12 rotors. Theyre a bloody good upgrade if you do some extreme braking. Otherwise they just wear your pads out faster and create more dust. On a road car id definately stick with plain rotors knowing what i know now.
general guide -- stay away from drilled, slotted are not so bad
Stock OEM replacements are just as good as these (combined with good pads and fluid)
why?
 dubbedup']
[quote name='JoKer said:
general guide -- b]stay away from drilled[/b], slotted are not so bad
why?
lol see the thread on "show us your/my crack" (il go find the link)
http://www.clubsub.org.nz/forum/index.php/topic,2492.0.html --> ok os they werent cross drilled but this is what happens to them. It happens in cross drilled lots more than standard or slotted rotors
Crossdrilled rotors tend to have a habit of cracking under heavy application... (really badly) and insta-ruins them.
Slotted rotors gives you the best of both worlds reducing glazing, and heat dispersion with out cracking.
drilled rotors are the problem i think, because they have been drilled.
but if you buy rotors with precast holes in them, then there are all good - From what ive heard.
