Clutch
your clutch is poked then..... get a new one. you can adjust the free play at the top of the pedal however but this wont fix your prob
your solution involved the spending of more money!
your not popular with me right now :(
Thanks for the advise tho :)
soory mate but its what i tell customers at work... although id rather have piece of mind than a fukd clutch half way to the moon if ya know what i mean
It's also pretty spot on, Worn Clutch Disc = higher engagement point.
 daleson']
You will be very happy once you get a new clutch that takes up in the right place, You find 1st easier to get into (and should you get to this point) you have no slippage!
I just had mine done. Cost $1k But that included some platic cover and nuts that apparantly have a habit of leaking. Regardless, Money well spenT!
Subaru NZ has had 3 prices rise's lately
Genuine Sti clutch for V4 is now just under $900 inc retail (parts only !!)
Priced a full engine gasket set / main and big end bearings for a job $1850 inc retail
WTF are they on ? Wonder if they sell whatever they are on :)
Maybe they should just out the letter P at the end of a part# so that we know whether we are funding their habbit buy buying that part !!
Clutch replacement isn't cheap when done through a garage. The cheapest quote I've had is $900, the clutch kit costs $580 which means if it takes them 5 hours to replace the clutch you are paying the mechanic close to $100 per hour for labour!
5 hours is a bit generous (except for a twin turbo i guess). and $100 an hour means im DEFINATELY in the wrong job
Wrong end of the calculator !!
900 -580 =320
320 / 5 = 64 per hour So about $57 per hour plus gst = VERY CHEAP
What about the $40 flywheel skim
What about gearbox oil?
Think maybe your B*tching about being cut a good deal !!!
Also at that price it NOT a Subaru clutch either, so best of luck with anything aftermarket !
 Ichi Ban']
900 -580 =320
$57 per hour is still generous considering most "average Joes" earn about $21-$22 per hour. IF mechanics are earning $57 per hour then good on 'em. I just need to save some dough to get me some good axel stands, a jack and decent tools and I'll be able to then save myself $57 per hour, even if it does take longer to complete the job.
 Andrew NR']
900 -580 =320
57 bux an hour is cheap! think about the overheads of running a workshop and you will quickly run outa coin. i know for a fact that ingham sears mer cedesat the mount charge 170 plus gst per hr
Yikes! I won't be complaining from now on. Still, to have the equipment and the know-how to do it yourself would be nice....maybe one day I'll get there.
a subaru clutch is one of the easyest to do ... roll pins for the front axles drop ball joints driveshaft off.. there is so much room its not funny.the pull type clutch mechanism is the thing that people trip up on...
