R3IN 34 MM X 42 MM
R3EX  34mm x 42mm
And a L set that is the same
The lines ground around the label are 1 2 and 3 . 4 is missing . 5 is present . From the front . If 4 was present theyd all be evenly spaced
Well theres a few other threads on the internet matching them as v2 sti ra.  With the tophat shim under lifters . Are these cams better / worse than anything else ?
And can they go in v3 heads ?
