Sorry if it's in wrong section admin
Hi am in a bit of a pickle if anyone can please help will be appreciated
Subaru legacy be5 b4 rsk 2001
I replaced the map/dome light after doing this the light is now staying on with it switched to the middle auto off function. When doors are closed it no longer fades out if I switch it to off position it goes off & on position it also works. I have put my old map light unit back in and this is now also doing the same ?
Looking online states could be a issue with the bci body module however finding mixed post some saying these don't have a bci unit?
All 4 switches on doors are working and all go off on the speedo I have checked fuses all seem OK. Is there a timer relay or some sort? I noticed there is a bleeper under steering column this controls the light around the ignition could this also control the map light?
Any input is appreciated
Thank you
