GFB valves leaking under high boost…
Gripless
So seems this is a thing! Found some USA forums with the same things back to 2017 where tuners won’t deal with them on aftermarket turbo setups.
It was fine with stock turbo and 22psi max ramping down to 15psi
Well made and good fit. Super easy to adjust vent vs recycle.
Wonder if their design is the issue?
Says will have some leak through piston ring which must increase with boost pressure so once you hit 25psi or more I guess they can creep open.
https://gfb.com.au/tech/tech-articles/14-diverter-valve-leaks-the-effects-on-engine-performance-and-tms-solutions/
Anyone else found this?
Well I replaced mine with a GFB Hybrid bov to fix my factory leaking bov, after a retune it definitely made a huge difference and fixed that issue
No leaks from mine however not running huge boost only 18 psi
