4 plug wrx ecu into legacy gt?
 boostin said:
AFAIK you just plug it in and it works.
uummm maybe after changing about 80% of the pins around ;)
Search for ReubenH's Single Turbo thread and there's an ecu pinout of both the 4-plug WRX and 4-plug Legacy in there and from that you can work out which pins to swap around.
It's a biiiig re-pinning job. I'm considering making an adaptor to sell.
It's such a pain, i'd do just as much work and convert to 3-plug while i was at it, it's what we did to ash's car. You can run forrester ECU's till you sus out the injecotrs, afm and maf sensor, then you can upgrade to STi with no hassle.
Guest itsgotgo
Which year ruebs? as the foz ecu is the same as v3/4 sti 97/98 stb forester. :)
As hes got a BF5 im guessing hes talking about the single turbos. In which case i think the ECU's are about identical. Which begs the question - what do you gain from changing?
Guest itsgotgo
well the sti ecu with the inj,afm,would in real world make you more power for the single and allow for more boost. :)
The foz standard ecu would not gain much if any. :-\
Woops, yeah, i was thinking of the TT 4-plugs too.
 Koom']
[quote name='keltik said:
I guess it depends on if your talking about the pre twin turbo GT or not
Good point, I was assuming it was a twin turbo GT.
The single Turbo ones are nearly identical.
And itsgogo, you're right, face lift manual TT's (the 3-plug tt's) have nearly identical pinouts to single turbo 3-plugs, ie, fozzies, wrx's, and STi's alike.
