hey
i've just had all my radiator cleaned etc as when coming back from aucks a few weeks ago radiator drained itself into resevoir to the point of nearly running dry but once kooled it would return to normal level weird i know
anyways the bugger is doing it again only this time res is empty too
What im thinking is the dreded headgasket would you agree???????
Chur T1M0
Or waterpump leaking...
Or a hose leaking...
Or the heater core leaking....
i do however know my heater core behind dash is screwed would this lead to anything still learning just when i think ive sussed it another unbeknown prob comes up and this is y im sick of subaru's lol
Guest itsgotgo
thermostat at a guess first.
easiest to do first,when they stuff out,no flow equals pressure,water gets pushed out,then when cooling sucks it back :)
Thats just a guess :)
just had that replaced when i had radiator cleaned
whats wrong with heater core behind dash is everytime your driving along especially cornering without the sounds cranking you can hear what appears to be trickling water behind dash went into tga subaru and they told me that it appears to be heater core and apparently dash n s*** gotta come out
That can cause overheating issues. And yeah, dash out, not fun.
That trickling sound is common, it's air in the system.
Fix the water loss and get all the air out of the system and the sound will go away.
Get the car looked at to find where the water is going to, get them to check for a leaking head-gasket too because now it's lost the water a couple of times that may have gone whether it was the original problem or not.
yea thats what im thinking god damn subaru living up to its name fullas didnt wanna buy one for that reason but got talked into it i think it'll be a hilux next or commodore lol but i'll still stick with the clubsub lol
Guest the_return_of_the_jedi
how high does the needle get on the water temp?
stays normal only rises slightly over hills in and out of whangamata but has always done that
just checked it yesterday thats all and was dry as a mofo
yea ill still support the club just wont own a subie i dont think
used to have older subaru when i was a teen but it hit a bank
Whats the difference between a auto and manual radiator ?? ?? ??
Trans oil cooler in the LH or bottom tank.
oh that'll explain the oil pissing out when i ripped the one out of the parts car
