after towing is it totaly shagged
well after towing my legacy about 200km. it apears the gear box is totaly shagged. its a shame i went for a spin before i hooked it up and it went so well. towed it away and then when i went to drive it. well it was as if it was jammed in park no matter were you moved the auto selector. then i get told not to ever tow an auto. am i looking at a replace ment or can it be fixed.. my thoughts are it is totaly shagged. right now after some perswasion the car is jammed in 3rd
Towed my old GT 350km at 110kph. It was well shagged by the end of that. Went backwards in park, made grinding noises in D and just seized up in any other gear. Clutches get roasted as the ATF fluid isnt being pumped around when the engine is off.
My thoughts were correct. I were towing it as I had sold it and had it on an A frame to deliver to the buyer (had a trailer sorted untill the last minute as well). after arriving at there place and finding that the box was shagged I hooked it back up and turned back around, with a thud and a skid i were on my way. I guess luckly for me the person buying it still wants it after i find a new box. never again will i buy another twin turbo. mind you I most likly ended up fixing everything possable on this car and wouldnt of had any more problems. but after afew problems and a pocket full of $ i'v had enough of twin turbos. gee i feel sorry for series 6/7 RX7 owners
 DRFVDR said:
yup it would have seized as autos need to have engine running to circulate the oil that is used to lubricate all the bits and pieces :(
some where i read subarus (ALL) should be either trailered or if flat towed then <30km @ <30km/hr
issac\nzkaosnz A framed his wrx from aucks to manfeild and back at more than 30km\hr and it seemed to be fine at manfeild at least....
Negative, my auto was still lunched even with the engine idling for most of the trip. It helps, but unless youve got the RPMs up - the clutches and bearings still roast as oil flow isnt great enough at idle
O ok. I think this is just karma for buying as auto ;D Best solution is to buy a manual in the first place ;)
 nztintin']
Manual. And *slightly* more than 30km ;) the commodore was soooo slow up vinegar hill aye jas/craig ;)
Manuals are fine - the oil is circulated by the gearset turning, which happens with towing (same as maori overdrive/coasting in neutral)
Autos are lubricated by the fluid pumped around with the torque converter, and if engine not running - no lubrication.
