I have a question for you.....
KING PIN
yes i am using a after market fuel regulator and running split rail setup ... the rail are fed thru where the alternator is towards the front of the engine and the return line is under the i/c is that how it is suppose to be ? i have set the pressure at 42psi on the after market regulator
  • Replies 52
yeah it will still have fuel pressure in the system no matter how you have it set up. it sounds "fuelly" however. maybe try another pump?
Double check your intake manifold gaskets, I had a very similar problem which stunted me for ages, but just turned out to be leaks around the gaskets (use gasket glue around the gaskets, both faces). Although I had a AFM error code (due to air leak),i would think you would also get a AFM error if it was a MAJOR air leak.
