I have a question for you.....
KING PIN
  • Replies 52
i have to make sure again... the engine is not ove heating tho... smels as fuel and when reved in neutral it hates to go past 0 bar and it starts doing pat boom phat sounds... am based in west auckland if anyone is keen to comer n check it out n help me out...
 log1call said:
White smoke out the exhaust?
That won't be unburnt fuel surely... it would have to be gallons of the stuff.
Are you sure it isn't oil burning?
That was the same issue when I had an injector seal fail... That could be the possible issue?
yea took all the injectors out cleaned themand placed them back in and now it fires up sweet but when you give it a immediate rev or if you put it in 1st gear and try to drive it , it will start plattering and phatting and yea cannot pull the load .. do you think my orange airflow meter is playing up .... and not being able to calculate properly... when i disconnet the airflow meter plug the engine dies instantly
id say if it idles and just wont go higher than 3k then it is running out of fuel or leaning out too much via an airleak
have you checked your crank case ventilation valve on the underside of the throttle body on the manifold? its easily missed
