Value of CD Blocks?
Ryan
 nt_a_foz']
[quote name='Koom said:
Put a 2.5L crank in it Brad ;)
i could haha..
Then what do i need the stroker pistions ay???
From my cloudy memory, rods are the same length, need stroker pistons which have shorter pin to crown height. Alot of companies do them.
Makes 2.133 L.
Does introduce higher loading into the rod bolts than 2.0L but at mid 200 kw power levels it isn't going to make much difference so the better spooling would be beneficial.
  • Replies 58
 funkytown']
the 2.133l engine then?
[quote name='nt_a_foz said:
You get a 2.0l block, 2.0l rods and stroker pistions and makes a 2.2 or thereabouts...
this requires the 2.5l crank?
i do know of one of those though haha...
That will fit in a cd block....
And as im getting parts from the states prices might be negliable difference for the pistions..
Koom, do you know any cars running the 2.5L crank in the EJ20 block? I have been considering this for serveral months to the point where I have sourced a crank etc. My calcs showed it would give a displacement of 2123cc with the 92.5mm oversize pistons, it would be interesting to know how much difference this would make, ideally some feedback from someone whos running this configuration. Cheers
No don't personally know anyone who has done this. Part of why I keep trying to convince everyone to do it ;)
We've done a long rod ej20 and have a destroked Crawford engine in the rally cars before, both of which give good torque. The long rod ej20 wasn't too far off the 2.35L but was a bit more high maintenance (mostly due to the budget of the owner i.e. Possumlink vs. Motec M800).
Has been people on here (back in the day) that had the stroker ej20 and reported good results. I wish that I knew about it when building my engine as I would have done it although now I'd build either a 2.5L or destroked 2.5L (2.35-ish).
