Impreza trans problem
Hi,
The auto transmission in my impreza has begun to slip I think but not 100% sure. When the car is cold, and I shift from "P" to "D" and accelerate a little bit, the car just revs up and doesn't move. It takes 2-3 secs before it goes into gear. But when the car is warmed up, it engaes fine.
Thoughts anyone? The trans oil looks fresh too if that makes a diff.
 funkytown said:
lololol and it wasnt even me that laid it down this time..
what can i say? i had the afternoon off work and i was bored :P
all good though, um well without seeing the car myself (i do trans servicing as part of my job) if the fluid is a nice bright red/pink color thats good but then it means you have a mechanical problem, as above could be clutch pack or something a little more serious. take it to a transmission specialist and they will be able to tell you exactly whats wrong.
oh and intro section here bro - http://www.clubsub.org.nz/forum/index.php/board,33.0.html ;)
Worn forward clutch seals is common (esp with sports shift trans)
Fairly easy to sort out - dont be fooled and let someone fully over haul your tranny, as it doesnt need it !
Parts cost is for the required seals and gaskets is around $200 plus oils and labour
 Ichi Ban']
I was going to say the same thing.
where you live?
I might be able to recommend someone for you through my contacts
[quote name='geta_subby said:
Upper hutt, Wellington.
How convenient..... ;D
