89 RS Leggy rear subframe locking bolts.....
wildturkey
after reading a thread on here somewhere (can't find it now) and doing some googling.......i got hold of a set of whiteline rear subframe locking bolts.
The instructions say.....'the hardware is designed to be installed and removed in between races'
It also says that the.. 'bolts should not be in for extended periods as it may lead to premature chasis wear'
This was all a surprise to me because none of the threads I read talked about this.........
So.........is anyone running the locking bolts full time? Have you noticed any adverse affects?
funkyRS073.jpg?t=1264925021
 BC5RA said:
They go into the rear sub frame and stop any lateral movement in the bushes under high cornering loads.
Increased NVH is the trade off for a tighter rear end ;)
I doubt many would complain about tighter rear ends....
 boostin']
damn that's a fine a s s
