gearbox is in, i have problems :(
ok so i got the gearbox into my bg5.
took it for a drive, everything is fine, but
when i change into 5th, nothing, i can't feel it change, and it just goes into nuetral etc.
anyone know anything?
cheers
rob
doubt its an installation problem , if you can get all forward gears, can you get reverse?? reverse uses the same selector rod as 5th, perhaps the roll pin through 5th selector fork is broken and the rod is sliding through it when you select. does the gear lever go into and stay in the 5th positon when you have nutral?
Using the right linkage? Pop the shifter boot off and make sure the selector isnt hitting the edge of the hole in the floor or something silly like that
oh ok thanks for that, i was thinking since it was my diff that went in my old gearbox, i could put the front part of the new gearbox onto back part of the old gearbox.
Would this be easy enough?
these are probly of your 5th gear syncro slider, there should be 3 in total , take the transer box of the back of the gearbox with it in the car and have a look , 5th gear is in the transfer box. although ya might want to check the rest of the box for damage which means its gotta come out, these are known for coming of of 5th gear.
Yeah my dads mate used to work for STI in the rally etc he said it was a common problem, i took apart the box and found a few teeth in there aswell, i have found a donor legacy, has rear end damage and has been writtern off, my legacy is a 95 and the donor is 96, the gearboxes still fit up to my engine, i will be using the rear diff from the donor aswell as mine is on its way out.
So would 96 be same as 95 gearbox etc?
cheers
