Cheapest Place to get Springs Fitted
Flat4
I'm planning on buying second hand lowering springs, so I'm looking for the best (cheapest) place to go to get them fitted (with wheel alignment) in Chch.
So far Mag and Turbo have given me the best price, although it's still more than I was hoping to spend.
Any suggestions?
in chch, they will have them cut and held in with cable ties in about an hour, no need for new springs,
only have to jack it up and take the wheel off to get the grinder in there :P
-smurff
Just realised I don't have any jack stands either (thought dad had some), so it will probably be easier and not much more expensive to pay someone else to do it.
Would it be easier to fit struts with the springs already on them?
I'm looking at buying Drunkenmonkey's KYB shocks and lowering springs for my leggy but being at uni this year I'm trying to be a bit more careful with my $$$ haha
well it would be easyier, no having to remove the spring from the strut.
just 5ish bolts on each corner and your done.
if you did this, buy the jack stands and do it yourself, or go to your local mechanic
-smurff
Guest boostcut
just use some blocks instead of axle stands... if your fitting lowered springs yopu will need to lever the lower arm up into place to line up with the strut and could fall on you head. :-\
+1
-smurff
 dubbedup']
[quote name='Drunkenmonkey said:
rather easy 5 bolts and they pop out
and a brake line clip......
really easy thing to do, and would recommend the job to a novice.
ahhh very good thinking, twist them 90degs, and the slide out. IIRC
-smurff
Guest TwinTurboImpreza
Chamberlain Suspension Ltd, aka, The Shock Shop
47 Sandyford Street
Sydenham
Christchurch
Ph: 03-379-5634
They are awesome at what they do, they do it right first time, no bull shit
They can do both jobs @ the same time
