1998 bg5 legacy
yellowsub
Firstly its spelt "Legacy"....
Are you trying to test whether or not the heads themselves are good? i.e.hardness test, getting them planed for flat surface
or just whether or not they'll bolt onto your block?
p.s. If you have a BG5b model the heads are essentially the same anyway.
Shim under allows you to use cams with longer duration and more lift than shim over. Also supposed to be less prone to the shims falling out at high revs (if its really a worry, upgrade to late model heads with shimless valves). In the world that 96% of us live in, there is 2/3's of f all difference between using shim over and shim under.
if you gotta rebuild, and you have the STi heads. Use the STi heads. If the engine is actually fine, and doesn't need building, don't bother, the GTB heads are more than adequate. I'm still using my GTB heads, they are juuuuuust fiiiiinnne. :D
