Content count
1,454 -
Dairusire last won the day on January 15
Dairusire had the most liked content!
531 my mum says I'm cool.About Dairusire
Rank
CS 2017 Committee / Admin
- Birthday 12/06/93
Drives :
2012: '96 250T Sedan (stacked), 96' 250T Wagon (sold)
2013: '00 B4 RSK Rev.C (sold 2014 June)
2014: '99 STi Type RA V5.10 (Twinscroll setup with complete v10 GDB driveline), Still own.
I paid up the last of my fuel lines and fittings for the RA and picked em up. It's one fat stack of fittings that's for sure! My ID1300X2's arrived as well. So parts collection complete. Maybe I'll have a running car sometime in my life lol. Sent from my TA-1012 using Tapatalk
But... You can get the genuine cast pumps for that price too? Here? But different strokes for different folks [emoji23] Sent from my TA-1012 using Tapatalk
Dairusire started following Anyone selling A STi?
Yeah. Back in 2014, when I bought my STi RA, I got it for 7.5k. Admittedly, it had 207k on the clock and it's been an absolute dog of a car. Most of that's my fault though.
That a branch off of hello kitty or something? Sent from my TA-1012 using Tapatalk
I went down to Ajays. Started wondering what to do with the loom. Have a v8 sti engine loom, to go with my V9 STi Spec C heads, that I need to match my V5 STi Type RA body harness. I obviously want to use the avcs, and I definitely want to use the coil on plug setup. From what I've read, better overall than wasted spark. However, I wanna keep the v5 sti manifold / idle control valve. So, do I merge the two looms, aka primary loom to use is v5 sti, then split the avcs / ignition wiring plus anything else and merge into the v5 loom. Or do I throw the v8 sti loom in, use Deutsch connector and lop off the factory connector and put those in its place and adapt v8 loom to the v5 manifold. @gotasubi any idea? Sent from my TA-1012 using Tapatalk
Just an fyi, gull don't have any issues with fuel delivery at all as they use a different supplier. Sent from my TA-1012 using Tapatalk
Dairusire started following NZ Fuel shortage Xmas 2017
All of them lol Gull in Birkenhead is current $1.67 for 91 and $1.82 for 98.... Gull in Forrest Hill with E85 is $2.05 I think for e85
Dairusire started following External gate
The short and tall of it is below summed up from the comments above. It's a few hundred $$ to just get something that will provide zero benefits to the vehicle While it sounds cool at first, give it a bit and you'll be over it more than hearing a child fart in your back seat. illegal for vent to atmo, which kinda makes getting an EWG a moot point? ????
Dairusire started following 80PRS on gumtree
Is the PRS range quite good or something?
Just quietly, we've been running full e85 in Furzes car since flatnats. And only last week. Replaced the fuel line from tank to the hardlines. They still seemed fine other than the typical 21 year old car line perish, that's expected Sent from my A0001 using Tapatalk
Dairusire started following Gull 98 in 2007 legacy GT auto
As @Andy_Mac has stated, could be just that. Gull 98, with it's 10% ethanol could be just enough for it to run better. Reason being, is that Eth is a great cooling agent. Combine that with 98 octane, and you've got a nice mix which makes for something a little more knock resistant. Not hugely, but in your case, maybe just enough. Short and tall of it is, if the car runs better on it, just run it on that. All Subaru's post 2001 should be able to handle it.
By chance, can you go to a part of the log of where you're at boost target and Wide open throttle?
update for Furzes Model: 1996 Subaru WRX STi Displacement: 2L Mods: Custom exhaust, 4 Bar map sensor, Turbosmart 44mm wastegate, Flipped V8 STi Spec C manifold, FMIC, 1000cc Bosch injectors, Aeromotive FPR, Aeroflow Fuel rails, complete teflon braided fuel lines, stock Version 7 STi Longblock w/ Supertech Dual Springs Turbo/Boost: Steve Murch Motorsport Holset HRC35/2 22lb (ish, and for both 98 and e85) Fuel: Flex Fuel BP 98 (275kw), e85 w/ 3.5bar base pressure (302.08kw) ECU: Link G4+ Plug in Tuner/dyno: @gotasuby aka @SAS
I'm now finally able to make a move on building my RAs new motor with the help of Ajay at SubiRex Automotive. New closed deck block on the way which is replacing the toasted old one. New head studs, have a set of bl/bp quad AVCS heads that I'm going to Jimmy in there. And of course will be running e85. I also created what is essentially an end to end engine bay fuel system spreadsheet. That includes all fittings you'll need, prices, places to buy from, part numbers and links. Hope you enjoy that as I'm 100% sure it'll help people who don't know where to go. Side note, there are -6 to -8 reducers in there. That's specific to my build. You'll need to change those for 5/16th hardline to -8 fittings. https://docs.google.com/spreadsheets/d/1Vf0T1Z7zlKoGg6GaD-NYnLt0NXM0JGOZmLKc6zk9wgs/edit?usp=drivesdk Sent from my A0001 using Tapatalk
All it needs now is a prodrive front bumper. That'd be the absolute business. Sent from my A0001 using Tapatalk
Who's Online 0 Members, 0 Anonymous, 6 Guests (See full list)
