  • 4 months later...
 ryn said:
It would appear one of my pipes ain\'t long enough.... Can you tell me what goes where and how etc from the pic. Cheers.
1. Block that hose which is Tee\'d off
2. Read argument online for pros and cons
3. Get confused as can\'t find any cons
4. ???
5. No profit
Short answer - that hose is teed off the BOV hose - it seems to make it open a touch on part boost / part throttle - guess to dull response a touch for whatever reason?
block hose = get response and *sometimes* 1 or 2 psi more on primary
  • 2 months later...
  • 3 weeks later...
top of bottom pic, from top of Secondary relief valve to differential pressure sensor on firewall via the steel vac tubes that run behind the tmic. Differential pressure sensor is labelled 21&22
  • 8 months later...
  • 4 months later...
  • 3 weeks later...
Differential pressure sensor, hose 22 is the boost feed from the secondary. Probably a CEL, VOD issues and secondary boost issues. Also a boost leak when in twin turbo.
