What ECU to go for?
l2eeFer13
So after hmmming and harrrrring about a ECU for my B4, I have returned to the forum for help
TBH i dont know a fricking thing about ECUs. All i know is that their not cheap and everyone seems to go for a Link G4 =)
So my combo goes as followed
I have a 99 B4 Legacy
Ej207 long block
TD06 Turbo
Equal length headers with a 3inch turbo back
550cc injectors
Probably have to do fuel pump but i havent gotten that far yet into digging
What ECU should i be looking at? I have a tuner ready for when everything is bolted on and running, I will never be plugging my laptop into the ECU and making changes myself.
So theirs like G4 storms, extreme, lightning, atom (some even plug and play but mines going to need repined no mater what)
And then theirs ECUs that plug into ECUs and wtfs
Im assuming that one has more features than the others like a basic/medium/advanced options list.
Came across this on Tardme. Seems pretty cheap comparing it to other Extreme links http://www.trademe.co.nz/motors/car-parts-accessories/other-accessories/auction-980183914.htm
So should i be going for a link or something cheap and nasty
link g3 or g4 are good from the tuners point of view, easy to use/upgrade/modify for extras. Can get plug in versions quite cheap 600-1200+ . You could get a plug in v5/6 model and it should fit your ecu plug setup, just have your tuner re-pin some wires before it's put in and you're done.
stay away from possum link or anything or that era - They have there place but it's for near stock cars to get a bit more oomph from a bolt in product IMO. Waste of time and money wiring one into a car like yours
Power fc could be a good option if you're going to re-pin the loom to suit they are quite capable but getting old and not as good as link
p.s good time to grab a wideband o2 sensor
Cheers Sly. I will be going be going with the plug in v5/6. If only they were a lot cheaper =)
http://www.speedtechnz.com/shop/brands/link/G4+plug+in+Engine+Management/Subaru/WRX+Link+G4+-+Subaru+Impreza+V5+V6+WRX+STi.html will get map sensor so i can delete the MAF
Will i need the intake air sensor?
Can you please explain the wideband o2 sensor and what i will need it for?
 evowrx said:
V7 sti throttle body will have a 2.5bar map on it.
Yep you need iat.
The dude i bought my V7 mani off completely stripped it down. Which f***ed me off cause i wasnt their when he dropped it off. So i was thinking of just chucking all the TT gear on the sti manifold while doing the split fuel rails and coil pack.
So i would need the Link 2.5 map now ae?
 evowrx said:
So you have no throttle body, rails or loom? Ive got a 2.5 bar v7 sti one here which will be spare soon.
Need mac valve boost solenoid too.
Nah I have nothing. I might just sell the bare intake manifold and buy a complete V7 one with fuel rails and all. So if I do that then I won't need the map because they already have one on the TB?
