megamac
BP Outback - Replacement Speakers?
14 posts in this topic
So after some quick internet research on the factory McIntosh system, i'm led to believe that the BP Outback is fitted with the EF-1080i amplifier, with 11 speakers including factory boot mounted sub.
Further research also leads me to believe that the front woofers are 6.5" and 8ohm? Unfortunately my speakers foam surrounds have fallen apart. Re foaming them isn't an option as many people say it sounds worse. So i'd like to replace them with some 3rd party speakers... But only 8ohm speakers I can find locally have an RMS of 250w, I assume they wouldn't sound great with the factory amp. Can anyone enlighten me as to a good replacement for them that will match with the amp quite nicely?
Share this post
Link to post
Bump. Same deal with me. I've read in places you need a slim fitting woofer otherwise you have to modify the door card or something too complicated for me...
Share this post
Link to post
i've actually got a complete Mcintosh speaker/amp/sub setup i'm no longer using if spare parts are needed.
And there's heaps of space in the lower hole for almost any normal component speaker, imagine mid woofers may be a bit harder to fit.
Share this post
Link to post
Any good tutorials for it? Just wondering whether to ditch the stock tweeters and use the component ones or not too..
Share this post
Link to post
What exactly are your plans there? Keeping the HU and amp but replacing the speakers?
Easier to replace the amp aswell then tou can do whatever you want speaker wise
http://clubsub.org.nz/forum/showthread.php?48404-Guitar_Guy-s-2004-Legacy-McIntosh-Stereo-Hack-Pic-Heavy
Edited by Andy_Mac
Share this post
Link to post
I just wanted to replace the speakers but if the amp won't run the speakers well then I guess I'd have to replace it.
I'm definitely not keen to do all of that in the link you posted, seems like too much work. I've already got a bluetooth kit for the McIntosh setup and can't be bothered messing around with crafting a new HU cutout or buying an aftermarket one.
Share this post
Link to post
Hi Smooth EZ - What did you end up doing? I have a '06 BP Legacy Wagon with factory McIntosh 13 speakers too. The sub-woofer has split soon after I got it, so I have repaired it but within two weeks it has split again in a different spot so just want it replaced. I am happy with the factory set up (I wouldn't say I play music really loud or anything) and have also installed a bluetooth unit so want to know if there is a compatible sub that can be straight replaced? cheers.
Edited by morry10nz
Share this post
Link to post
Think it comes down to what particular subs work well with the extremely limited available wattage from the OEM amp. Think there is a walkthrough somewhere about a sub amp gain to get more juice going to the sub. Vaguely remember reading it somewhere and pretty sure it was for 4th gens.
Share this post
Link to post
On 8/11/2017 at 8:45 PM, morry10nz said:
I have managed to source a rockford-fosgate-p3sd4-8-8-4-ohm-shallow-subwoofer from Rapid Radio in Grey lynn which is 8" shallow sub and also 4ohm. Am i right that this should work as a straight replacement or am i overlooking something with these complex Macintosh factory set-ups?
That sub is a dual 4ohm voice coil so it can be wired up at either 8 or 2 ohms.
I would remove the factory sub and find out exactly how much room you have to play with and check the resistance of it to double check it is 4 ohms. With a low power factory amp you'll want to find a speaker with a high sensitivity or sbl. For example the one you linked is rated at  SPL (dB @ 1w/1m):82. Thats 82db (volume out) 1w (power in) 1m (distance)
https://www.abtec.co.nz/Polk_MM840   This has a higher sensitivity of 90db1w/1m  so it should be louder with less power and it is 4 ohms. the only thing is that its 40mm deeper so unsure it will fit as i dont know how much room there is.
There is a few other factors but these are the main ones. Hope it helps :))
1 person likes this
Share this post
Link to post
MM840 is the one the Aussies recommend so it must fit without much trouble
Thats the back of a facelift wagon one.
1 person likes this
Share this post
Link to post
oh wow that is low power haha. would definitely recommend wiring up an aftermarket amp to the factory system for a lot more punch and a better sound  . this can be done using a line level converter. https://www.jaycar.co.nz/speaker-high-level-to-line-level-converter/p/AA0482. connect the factory sub wires to this unit and rca output to the amp. the amp can be hidden under a seat and keep the sub in factory location for a stealth and clean set up.
Share this post
Link to post
