The new phototype flat 4 for the Next Gen of Subaru
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
Ive seen a pic compairing this photo to the only shot showing the GT5 under bonnet of the FT-86.
You can see similaritys.
Ive heard it will have direct injection, timing chain, be lighter and shorter?
These engines may be out by 2011 or 2012? Thats the possible dates for release of the FT86
 aim said:
Won't the plastics mean shorter engine lives?
The plastic intake will not last as long as the alloy one but it will probably outlast other parts of the engine.
AFAIK the STI still uses the metal intake presumably because it has to cope with higher pressures...
 the_return_of_the_jedi said:
plastic only there for weight saving...
Only weight saving ???
What about raw material cost, manufacturing cost, less wear on tooling i.e. maintenance cost etc etc? I think the lighter weight would be a reasonable way down the accountant's list of pro's vs con's.
 Koom']
+1
-smurff
Guest the_return_of_the_jedi
oh yeah of course , but ultimately if you can have something that weighs less and cost less and does the same job then why not
Guest boostcut
weight will be nothing at all to do with it... cars are built by accountants, not engineers these days so plastic is the best option, toyota have used them for years.. since 1998?
the first performace reasoning i came up with is plastic wouldnt heatsoak like alloy does so would make intake cooler.
the first performace reasoning i came up with is plastic wouldnt heatsoak like alloy does so would make intake cooler.[b/]
this would probably be more beneficial than saving a kg in weight
-smurff
Guest boostcut
it doesnt have 90 degree hot water running thru it for the entire life of the car... a bit of boost and 40degree air wont do much... plus if it does crack, get your hot glue gun out lads...
