HELP! BH5 gtb not starting
cuscogtb
  • Replies 75
 boostin said:
Didn't you check if all the timing marks lined up?
not at the time was too stunned by the state of it but looking through the pics we took i found this one.
doesn't look lined up, looks like one of the markings on the belt is 3.5 teeth across to the right ??? :o that can't be right...
do not remove the old belt until you confirm how the timing was, get someone who knows to check it.
you need to know if the timing is causing the problem. if it isn't, and the timing is good, changing the belt will be a waste of time - although i agree it needs replacing.
im back sunday morning but i really dont know if i'll have time - i have a truckload of things to do within 4 days before MM
 kamineko said:
it was very weird
ive only heard that kind of stumble/stutter/pop/missfire when i had wired my ignition in the wrong order
still love to know exactly how the belt can jump. sure the tensioner was ok? did you reuse it?
yep reused..... :o
 dubbedup']
[quote name='keltik said:
When a bolt gets stuck between it and a cam pulley im sure it will jump :P
yep this is my theory, you can get them to jump teeth just by doing up the crank pulley nut...(maybe wrong way - too tight etc)
that doesn't sound right?
