No spark after rebuild
JWDRPN
my car has just been top to bottem rebuilt..it came the day today to start it and there is zero spark!! there is power going to the ecu but not coming out
i have a power fc..which was working perfectly 2 months ago when it went in and was brought brand new just ova a year ago!
immobiliser maybe???
im not sure iv spoke to the mechanic he said he tested it the ecu is getting the signals but theres no signal coming out of the ecu
which is y im thinking immobiliser isnt hookd up or smthing along those lines
i dont think the ecu would be fried it went in perfect
take the computor out and send to anything electronic in nelson.. they dont charge if theres nothing wrong... good c.nts thats after you go through all the plugs etc
Is there power to coil and injectors ?
They are NOT fed power from ECU
Most of ECU fuction is to provide earth various compnents
Check main ECU earth on rear of manifold
Check Cam and front Injector plug on passnegers side, seen a couple no starts due to this around the wrong way
Do you have CEL operation? ie on with key.. If so any codes in memory with diag check?
Does fuel pump prime? does fuel pump run during cranking?
thanks itchy ban!
i havnt actually been out to my car as its about an hour away i just got a call today to say he cnt get the car to turn over hes checked the basics even had an auto sparky in but he was just checking power to the ecu!
il call him first thing give him those ideas!!
all this money i thought id finally get my car back now im scared my ecu has gone...even tho it went in perfectly going..yup power fc has even had 2 tunes
Don't stress
If ECU ran before it will run now, you have prob a much better chance of winning Lotto as the chance that your ECU died between removal and refit of your engine
Best get your mechanic to ring me !! Need better info than that, ie do the Inj have power? are they get an earth pulse from ECU ?
Otherwise this could take months to fix !!
Send me a PM and I'll reply with my Ph#
  • 3 months later...
