factory subaru 4 pots.....will they fit a 99 Foz?
Guest the_return_of_the_jedi
i would suggest the rotor size will be differnt..
can anyone confirm
 GNEDEF']
can anyone confirm
im sure they would be differnt to 2 pots...as a sti (4 pot) rotors are def bigger than nonsti (2 pot)
Yeah but the 4 pots have integrated backing plate mount thing whereas the two pots are in two peices, which is why you can bolt a set of 4 pots straight up to a wrx as long as you get the matching rotors too.
TL;DR if the forester has the same 2 pots as a wrx, the 4 pots will fit but they'll need to get matching discs
 B4 2000 said:
I know they will fit legacy BE/BH, as have they have the same rotor size 294mm but the only difference is the legacy comes with 2pot whereas the sti with 4pot.
Don't know about the foz
+1 on BH, tell the guy/girl to measure the rotors...
