DIY air box
kingersman
 kingersman said:
you must have a tiny screen ahaha
heres a larger one
I see two major problems, Problem One how would you get air to it? Bonnet vent? Problem two its on a mitsubishi
Legacy :P you can find anything on TM... (well almost)
but its my spare sorry not for sale! i made holes in one of mine to incorporate extra intake from my modified bonnet scoop
Get a bit of cardboard and run it down the chassis rail from the strut tower to the headlight. Cut holes wherever something needs to go through it. Then, once everything fits, use the cardboard as a template and cut it out of a piece of alloy sheet. Put little flanges down the bottom and put rivnuts in the top of the chassis rail or use pre-existing threaded holes. Easy......
this is what i did. but i have never posted a pic on here so if you want a template made i can send you my one.
no its one piece of alloy, it has tabs bent on bottom and top(for a lid) the filter and afm bolt thru the alloy, so it supports the afm at the same time. i also sealed it so i can fill it with ice if i feel like it.
