Help Please.. CEL
Morning everyone, On my way to work i was going up haywards and my speedo stopped working, stink as. Then 20 seconds later check engine light came on and the car was backfiring under de acceleration. Checked CEL code and its 11 and 24, 11 crankshaft position sensor, and 24 Idle air control solenoid. Anyone got some spares lying around that i can purchase? Car seems to drive fine apart from the backfiring and no speedo.
Cheers Cody.
they might be old codes, clear them and check again
the ecu does require a speed input for smooth driving. if you disconnect the speed sensor the engine will miss and run pretty rough unless your just idling. i'd check that sensor first, at the gearbox side (beside the turbo) because the dash gets the signal first then feeds it to the ecu
same as CJ271's syptoms. his has thrown a 33 though.
cud be a broken speedo cable as well.. mantis is a v3, so still a mech feed to the cluster.
Yeah im assuming the speedo cable is broken easy fix, the other 2 not so much.... Expensive? Cable priced up between 60-70$ Tricky to install? Best to buy brand new ones or try source some 2nd hand ones?
Sweet as, will the cable affect the other two things? Car is back firing badly though so i guess something is up. I will replace the cable and go from there. Best place to get cable? subaru itself?
Guest Oscar
 kamineko said:
inspect it first, it may have just un-cliped or something silly
no they're not related. as i said, find out if the other codes are persistent. your speedo is likely the only problem
This.
Your car would not go if the crank sensor had shat itself.
it'll be the small plastic bit where the speed sensor sits on the gearbox - pulled out a broken one before and it looked partially of plastic composition
you coming out to the meet tonight??? one of us could look at it..
So i pulled the crank sensor out and it was filthy so gave that a clean. Pulled gauge cluster out and the cable was in firmly, disconected it from the gear box and sure if enough its broken. Got a new one coming from subaru. Car still has an eradic idle and nearly stalls everytime i come to a complete stop and backfires alot so i have some upper engine cleaner coming so hopefully that fixes that... fingers crossed.
Well new speedo cable is in, upper engine cleaner is done and have cleaned the crank position sensor and everything is sweet as again. That upper engine cleaner is awesome, engine is quiter, idle is steady and very happy with the results, worth every penny.
