B4 Legacy - fuel pump controller? Or wiring diagram?
Optical
Anyone know if B4 legacys have fuel pump speed controllers? If so where they're located?
I suspect they do and it's by the steering column, but there is another mysterious box behind where the lighter socket is...
Also anyone have a wiring diagram for these things? Pref with the loom layout in it
 99GTB said:
The speed controller should be in the left hand side of the boot behind the panel.
Is that a sedan or wagon? does it matter? Going to look in the boot now... Is the panel on the floor or on the side?
I dont see anything behind either fuel tank hatch if that's what you mean?
tried to find the info in the manuals i got, but the files not being labeled so good, its a bit of a struggle at this time of night :(
-smurff
haha, I think it's the eatass version. Geesus Americans should not try to make technology
They dont reference EFI that i can see so what it's doing in this car is beyond me.. Ah well hopefully it solves my problem :)
 99GTB said:
Here's the mod done, pretty self explanatory...
Certain does about say it all.
Um, yeah, me and chris just ran a new wire directly from the ECU to the fuel pump relay somewhere in drivers foot well.
The GTB ECU fuel pin supplies a minute (i think 0.7 volt) signal to the controller for fuel. Where's the same gen impreza or forester ECU's just switch ground. Both use the same pin though.
