RWD DCCD?
pl0x
 sultan said:
obviously it's a different analogy for dccd as it's not 50/50 split. if power is going some where and then gets diverted else where, it doesn't magically get to the wheels without that same heat and friction and inevitably power. 200kw 50/50 going to two places is 100kw through the rear diff. 200kw going to one place is 200kw through the rear diff. 400kw going to two places is 200kw to the rear diff. it's not rocket science
a 50/50 differential doesn't mean it splits the power and sends half one way and the other half the other way. it means the same power is going both ways at the same time.
if i was as you say, doubling the power going to my rear diff, i think i'd be shitting them pretty quickly dont you?
 driftrex']
if i was as you say, doubling the power going to my rear diff, i think i'd be s***ting them pretty quickly dont you?
so a 200kw car, you think each of the four wheels is putting out 200kw?? i don't think physics would agree wit you.
and my original point was, if you're putting out beyond std power, yes you would have problems with diffs. but you are not putting out more than std power
 sultan']
Read up on diffs like suggested and you will learn something
Also its not just about how much power you have...
Differentials transfer torque. Kilowatts are a measurement of power. A differential that would happily take 100Nm at 25,000 RPM might explode if you fed it 833Nm at 3000 rpm - even though you are producing the same power figure of 260 odd kw.
