1996 Wrx STI Engine problems
Standard reg ay. have changed it to another standard one & still same prob. Ill go get a new one this week.
Only mods to motor ect are
500hp fuel pump (got it in car 2yrs ago)
VF23 turbo (V3)
cold air intake
greddy bov
3" exhaust from turbo
Fully rebuilt 400km ago with standard everything
take your bov off and see what change it makes. it sounds like its leaking and causing issues. but on boost it wont be a distinguishable problem
the ones in the base of the fuel rail? as he has changed back to grey inj. and still has same problem
i dont even know why we try to diagnose problems over a forum. no one wants to help themselves.
just remove them first and see if theyre damaged... no use spending coin for no reason. and a full set of seals from petroject is like $140 i have a spare set of base rings if those are the ones damaged
Tryd removing the booster hose & its idle just came up alot & was still missing & I removed the bov with no change. I have had it put on the computer at ch motors & the afm was playing up abit so got a new 1 & still no change sadly. Its going into the shop tomorrow to hopefully get sorted out as my fuse with it is a tad short after 2mths of working on it.
Thankyou all very much for all of you help & I will post up what it was as soon as I find out.
Hey guys thanks again for all the help. Got the car back today ended up the afm was totally stuffed & the o2 sensor wasn't much better & the little switch at the top of the accelerator pedal is sticky so just got to fix that & I'm sorted.
