Ive got an intermittant clacking noise in my right head..
stira
Its loud enough to scare me, but definately sounds rocker coverish rather tahn blockish.
Its a 99 type r but has a v7 block and gtb heads I think. When it happens it starts to run rough, then it picks up again and runs smooth as. Doesnt sound like piston slap or normal lifter noise.
Im suspecting valve or rocker somethinish.
If the heads are from the same year as the car (offset bolt pattern on inlet manifold) they may be shim over bucket which have a higher likelyhood of throwing/breaking a shim, which could casuse the problem.
Those heads dont have rockers and as they are solid lifters Proma/MBL8 wont do anything to fix you problem if its in the head.
I'm not a mechanic though, I just read it on the interweb thingee
