external wastegate problem
black_wag
it has a removable flange where the screamer pipe on it bolts back into the exhaust to run to the atmosphere. i unbolted that piece and now its blowing exhaust gases out that pipe and sounds like a tractor. havnt touched the vaccuum hose. it only has one of them with the boost tap on it
So you did block off the hole left in the exhaust from when it was plumbed in? :D The valve seats probably leaking bypassing a slight amount when closed.
have you plated over where it plumbs back into the exhaust ??? is this where you are meaning & not the w/gate itself ???
If Im reading it correct, that you just took off the external wastegate... If thats the case then yes, you need to block it off/pur the external back on otherwise you have just got urself the mother of all exhaust leaks lol
You have answered your problem in your question if Im reading it correctly. ???
 WRXER said:
Good to see you back mate, been quiet round here. ;)
yeah just got my car all fully legal and running right now. certed for everything and went threw vtnz for a wof with a full clean sheet. not bad i thought for the car sitting round for the last year and a half
 black_wag']
I bet that he was talking to Monolith.
So you're saying that you just got your car certed/wof/running right etc etc then decided to pull the external apart too make more noise and now it's making too much noise?
And it has been asked, did you blank off the hole that is left in the exhaust?
 Koom']
whats your deal mate?
