cost to paint mags in Auckland...?
powdercoating..powder sprayed on to what ever you are painting and attracted to it by an electrical charge to make it stick.Then baked in an oven to turn powder into paint,a bit like enamel on pottery.Good durable surface but does give a buildup which can cause clearance problems on tight fitting items.
Paint...is just paint.Brush,spraycan or spraygun.
think of it as a dry form of paint (powder) it gets electrostaticly charged to the surface and then sent through an oven at around 230 degrees celcius. it doesnt turn into paint though..it just cures and sets on the surface...
there shouldnt be any build up if its done by a pro :P ( you can adjust and change every setting for the powder output...so shouldnt be too little or not enough like what can happen with spray painting....even if there is a build up..it should only be a few microns if that so shouldnt be any problems :)
