lotsa codes where to start
dubbedup
ok im getting the following codes on a 93 wrx, are any other them related, the only thing taht is odd is a high idle everything else is sweet as...
14-17 - injectors
44 is wastegate solinod, so hopefully this is just unplugged or a bad vaccumne line etc.
24 is idle controller, so that explains the high idle
31 tps - no idea why this code is spitting out
could this be one thing that is setting of a whole heap of codes
how do you check all these code man?im abit confuesd..alot of people on here say they check there codes and stuuf.id like to hava look at mine.iv had it scaned at the macanics and the only fault was afm.
yeah all earths on cleaned and put on ok, was talking to the old owner and he said check engine light came on before it got stolen but did not affect it, as it has started idling high I would like to get this sorted mainly, just dont really know where to start, lol searching for inspiration/motivation as what it could be....
 dubbedup said:
would it not just throw a AFM code?
Any ideas on how to start testing some of these faults?
haynes manual bro all the diagnostics are in one . it sucks but unless you just start replacing stuff? but that will soon get expensive have ya got a muli meter?
How to test the Throttle Positioning Sensor (TPS)
Here's the procedure out of the chilton's manual to test the TPS switch.
1. Turn the ignition switch ON. 2. Measure the voltage between the ECU connector terminal and ground.
Voltage should be as follows:
Terminal 2 and ground: 0.7-1.6 volts with the throttle fully open
Terminal 2 and ground: 4.4-4.8 volts with the throttle fully closed
Terminal 3 and ground: 5 volts
Terminal 1 and ground: 0 volts
3. Ensure voltage smoothly decreases in response to throttle opening. If measurements are not within specification, check and repair ECU terminals or harness.
4. Disconnect the connector from the throttle sensor. Measure the resistance between throttle sensor terminals 2 and 3. Resistance should be 12 kilo-ohms.
5. Measure the resistance between terminals while slowly opening the throttle valve from the closed position.
Resistance should be as follows:
Terminals 2 and 4: 10-12 kilo-ohms with the throttle valve fully closed
Terminals 2 and 4: 3-5 kilo-ohms with the throttle valve fully open
6. Ensure resistance smoothly increases in response to throttle opening. If measurements are not within specification, replace the throttle sensor.
7. Disconnect connectors from ECU and throttle sensor.
8. Measure resistance between ECU connector and throttle sensor connectors.
ECU terminal 1 and throttle sensor terminal 2: 0 ohms
ECU terminal 2 and throttle sensor terminal 4: 0 ohms
ECU terminal 3 and throttle sensor terminal 3: 0 ohms
9. Measure resistance between throttle sensor connectors and ground.
Terminal 2 and ground: 1 mega-ohm minimum
Terminal 4 and ground: 1 mega-ohm minimum
Terminal 3 and ground: 1 mega-ohm minimum
10. If resistance is not within specification, check and repair the harness or connector.
Here is a diagram for the pin-outs.
could it be a voltage thing? the car was stolen and had all the loom chopped, the owner/police recovered the vehicle b4 they took the motor and box out, altho it was all just sitting there ready to pull, but it the bolt on parts were removed, and have since been replaced...
do you think they could have cut through the loom while the battery and everything was still hooked up ? could have shorted out everything.
semi off topic - i have just put in a re-map'ed ecu to run yellows in my BC5 & i tried to run it with the greys in & my map sensor disconnected,
It threw check light & codes 14 15 16 17 & 45 these being the 4x injectors & the map sensor, so i installed the yellows & hooked up the map sensor & proceeded to clear the codes (It seams to run mint & the air fuel mixtures are good with the Innovative Wideband system hooked up)
But it will only clear the map sensor & still flashes the 4x injectors??? & throws the check light when not in check mode.
Now this is where it gets interesting, after disconnecting the battery,
I removed the re-map ecu & installed my normal modcontrol chipped ecu, re-connected the battery & it started sweet as & did not throw any trouble codes at all NONE..... it idled high so we used the apexi safc to enable it to idle as normal taken out for a few runs & i have removed the map sensor pressure source again, seems ok, but i'd like to know why the other ecu is flashing the just the 4x injector codes when this one is not???
weird aye sorry for the thread-jack but it might have something similar, also running the green afm too
