bh5 motor in a bg5
infinite
FYI:
bh5 motors have a 4pin tps... but only use 3 pins. u can put a bg5 motor loom onto the bh5 motor and chuck the bg5 tps onto it aswell. will be posting up a way to wire up the bh5 iacv valve too.
also u can put a bg5 throttle body onto the bh5 motor but u will need about a 19mm frost plug to plug up the iacv valve. then your motor wont run or have any iacv sensor.(have seen this done alot on evo's that are for drag motors)
 mattapo said:
what about compression ratio?
yea true Matt, i of all ppl shud knw that! :D BH5 are 9:1 CR and if yr gng to use a v3/4 STI ECU (8:1 or 8.5:1) you will get detonation like its gng out of fashion.
the comp ratio (so i believe) is built into the pistons so you cant evan just use the bh short block.
Of course with a link ECU you can do any thing with the senario you are faced with.
i say forget fluffing around, get the entire BH5 engine and get a link ECU (may be a wire-in link as you essentially have a v3/4 loom and would need a v5/6 plugin link ECU = no worky)
  • 1 year later...
