Upper engine cleaner doing any thing but good ?
WRXONP
Any one ever done upper engine cleaner and it make it worse ? My car seems to run worse since I did this ? It possible that its stuffed the spark plugs ? It has like 3 times had a miss on mid power at lower boost level (not full throttle) and just did a boost before and as soon as I hit full boost it just miss fired ugly as . . . Just wondering if it could have damaged spark plugs ? Going to pull them out after work tomorrow to check
Definitely check the plugs, could be several other issues otherwise ultimately do a compression check if all else fails. I had the same issue, which resulted finding out compression was down on one cylinder sigh. :-[
mine was hard to start.
check this out when me and spencer did mine.
mine has smoth the idel out abit more.its not designed for a noticeable change.its just getting all your gunk and s*** out of your motor
 sti8u said:
iduno about the ivac one.ididnt do that.just into the inlet.still have problmes with it today?
na na iacv will be sweet. use to do it to the GF (not girlfriend :P)
For me the cars were always hard to start at first and off it goes hot boxing your garage!
got it runninh mint tonight..dont know which the fault was as i did a few things...
changed spark plugs
changed back to the red ht leads i have
sealed between the pod and the afm as it looked like possible leak
reset the ecu
seems to be going mint now
changed spark plugs
reset the ecu
could be the leak between pod and afm if its got a leak afm getting a fucked up reading.
