2003 wrx volt drop readings please help
i have a 2003 wrx , can anyone help me on the voltage reading of the car . i installed an apex timer and one of the functions of it was the volt meter , the reading of my car was 13.7v but it goes down to 12.1v with no load or anything but when the fan turns on or aircon compressors turns on the voltage starts to increase again is this normal ?
took car to a auto sparky problem is solved now. the volts should be reading 14v all the time. its a ecu problem not telling the ecu to turn on the regulator
This is correct, it was an emmision related item, the ecu controls the reg
The alt only charges when needed
