RSK b4 fuel filter
G-unit
filter IS in tank - drivers side with pump assembly
Note make sure tank is LESS than 1/2 full when changing otherwise fuel goes everywhere !
Genuine cost for filter and O'ring is $40 odd from memory (refitting the filter outer steel case is tricky to get on right , will cause poor drivability problems if you get it wrong )
 JoKer']
in tank?
yup in the same unit as the fuel pump
basically you pull the fuel pump out and change the filter.
ow and make sure you have not got a full tank
under half and you shouldnt get wet :P
[quote name='rockr said:
when i went to get one for my 01 rsk i was told they dont have one , just rely on the sock on the pump in the
tank.!!!
and thats why people end up with f#(ked fuel pumps on these
