Boost Gauge Installaion
markw336
hi there i have just brought a mechanical boost gauge for 11.50 brand new type R so not a complete crap brand haha and i know where to find the power for it and what not but was wondering where i tee of the pipe to read an accurate pressure of boost i was thinking the vacuum line of the BOV or somthing liek that but im not to sure
Aren't type-r the people who make all those cheap plasticky "attach your cellphone to your air vents!" products? :D
Should work fine off that line, I've always had mine tee'd off of the line between the wastegate and boost solenoid iirc. Closer to where you're threading it through the firewall if you do it from that side of the engine too
actually come to think of it your right it is that cellphone holder brand owell guess i cant complain for 11.50 for a rnad new boost gauge haha forgot to mention that i have a twin turbo legacy so between the wastegate and boost solenoid would only read one turbo guess that means the same for the BOV
ok well i have installed it as it turns out i dont have any pressure running in line 22 or 21 so i taged onto the BOV line and bam it works ive had a small test run it seems i have about 12-13 psi on primary and spikes to 14 which is almost overboosting will throught up some photos tomoro
 markw336 said:
well on the way out i broke the gauge now sits at 10 vac... but it was pulling 17psi on secondary and i think i scared my self a litle bit haha never gave it a good go before one hell of a wagon
You get what you pay for!
