Crap reception
Hey lads and lasses
Am having a real issue with my reception. Is there such a thing as a wireless antenna booster or something of similar description? Like my standard radio for the aesthetic look....
 Evokillaz said:
2002 WRX. Aerial is in the glass and I am located in Auckland.
Band expander is installed, just seems extremely average reception wise!
what mhz is the band expander? i have sold boosters for holdens before which sit in between the aieral lead and the unit. im sure they must be able to work with subaru aswell. the one i supplied the customer had the euro style ends on it so just need to switch to jap ends
The glass antennas in WRX run an amplifier that needs to have 12V to amp the signal. The wire for this is located below the 12v+ wire in the loom at the stereo. It is usually a white or pink or blue wire. Check if this wire has power on it. If not you can cut it and connect it to the ACC wire (usually yellow/red or yellow/green) and that should sort it.
Try a proper (non Jap 76-90MHz) radio, and since you're in Aucks - look for one with RDS. The new Pioneer ones like DEH-6350SD or 8350SD are good options.
I've found the newer cars with amplified windscreen aerials to be a lot better than the older automatic up/down ones or the A-pillar pull-up types.
Side note- would using a direct 12v power to your head unit (instead of via loom) increase volume and aerial signal / reception?
The car is a forester but this is the first time iv used a harness to loom setup versus a fused 12v straight from battery.
I mean if it doesn't get better, il just run all speakers off an amp instead of off the H.U
yeah clean power and ground feeds would generally help. the factory ones split thru many looms... even the ground wire commons to about 4 and is grounded somewhere along the loom. get the clean metal chassis directly behind headunit mounting and ground it there. use star washers and locking washers where possible.
