250t overheating Q
will i am
ok
just done heads in a 250t 95 legacy i purchased for cheap.
new cambelt idlers tensioners, thermostat, rad cap
havnt changed water pump....
problem is starts going into the 3/4 area on the temp gauge
if i just cruzz it gets hoter
if i put my foot down it drops back to normal
has anyone had this problem before?
hopping its only waterpump i need to change
or have ppl had faulty water temp sensors before.
ow and it is all bleed up right
partially blocked heater core - dash out to replace (and they MUST be replaced not rodded out )
That would have been the cause of the Head gaskets orginally
  • 1 year later...
