MAP Sensor Qs Installing a 3bar
slyrwd
i can post a pic of mine tomorow .
if you sensor has the same harness as mine its
red = 5v
yellow = signal
black = ground
this is what i found on the net but i had to end up using the internal map sensor on my g3 because the ecu couldn't see the map sensor.
so i think i may have the red and yellow around the wrong way .
so please post you finding as im keen to know :)
in my RS BC5 the wires are:
To the plug is
Red - green stripe
Yellow - black stripe
Yellow - green stripe
Plug to factory map is
Green
Pink
White
New map is
A = Black
B = Orange
C = Yellow
Photos are good!!
Cheers guys
