Version 7 factory fuel rails ok to 270kw??
tez n u
Does the silicon inlet pipe make more power on a td06 or even a stock vf turbo compared to the stock intake pipe to the turbo? It is defiantly bigger then the factory one and i can hear the turbo spooling up a lot more now but has anyone ever seen a dyno figure of how much of an improvement it gives??
It really sucks haha. With the turbo whistling at 100km cruise. I've got a 16cm housing coming to hopefully fix it. It's really good for passing though nearly too good you don't really realise how fast it picks up speed in top gear and gets you in trouble
 grego0o']
[quote name='gotasuby said:
2.5l avcs twin scroll with a hx35 turbo. Fmic etc
Interesting, what power? And what rev limit are you running? I run a ej257 with avsc and a gt3540 and it spools up nicely too. What heads are you running? Cams?
The problem I have is I tune all myself so not sure on power but have maxed sard 800cc injectors at 11.5afr. Red line currantly at 7000 as Injectors maxed. From previous setups as comparison I would say I have 270-300wkw at 20psi. I need a bigger exhaust housing installed to get above 300.i have just v7sti cams with ported heads and + 1mm valves. Am looking at getting kelford 272 when I get met injection
 gotasuby said:
I ran 24psi on a td06h 20g on a forged motor but v7 is forged so I would say go for it just won't last as long as less boost.
Yea i wont be running 24 psi much, maybe once or twice at the strip :) will probably run max 20-22psi as usual high boost.
