reverse light not working
slystiguy
Got a test light? Use it on the light terminals to check weather its getting power through to the light.
You can use an led or brake light and some wires if you dont have one.
If it doesnt light up then trace the wires back to the next connection and try there.
Keep going until you find the broken connection/fault.
It could be something as simple as a dodgy ground.
gearbox sender unit get full of oil and stops connecting,easy/cheap/temporary fix is to remove it and full with brake clean( push little ball in to do this) dump oil/cleaner mix out, do this a couple of times and it should last a couple of years, permanent fix is to replace the sender unit.
Oh this is based on a/ it is a manual and b/ it is an early car ( 89-92 legacy, 93-96 wrx)
Check the wiring that comes out from the switch on the gearbox, Pop it in rev with red lights on dash and wriggle the wires.. if that doesn't help then remove switch and inspect it could be worn out, push button in and out and see if that works or even plug another switch in and see if you can get rev lights to work .
