What diff ratio
 cpt kernow said:
3:9 sounds better than 4.44.
Check scoobymods they've got a list of all specs there.
I read somewhere (in a spec sheet) that all Imprezas have 3.9 where as legacy's and Foresters have got the taller highway gears
the STI's have 4.444 and RA's ver1/2 have 4.111. Its random as what has what. I think the old v1 RS had a 3.9
* not a complete list
 funkytown']
The early legacy auto's had 3.9. The RS was 4.111, GT 4.444.
3.9 is the "longest" ratio and 4.444 is "shortest"
Then how come the NA's have 4.1's and turbos 4.4's
For example
my mates legacy tz sits at 3100rpm at 100kmh
Another friend has a v5 sti wagon 2900 at 100kmh
My s/tb sits at 2700rpm at 100kmh And mines definately got the 4.44:1?
Odd. Looks like time for google!
With both of those gearboxes shown, they have different top gears (as well as final drive ratios) and those 5th gear ratios are pretty tall. So it doesn't all come down to purely the final drive ratio, its a combination of fifth gear and final drive.
You'll find that STI gearboxes are often around 0.825:1 for fifth and RA gearboxes are 0.972:1
The V5 STI's had a "taller" fifth gear than most STI's (i.e. 0.738:1) but also had a 4.444 final drive.
To get your head around final drive ratio's etc, think that for a 4.444:1 ratio diff, the driveshaft has to rotate 4.444 times for the wheels to rotate once. For a 3.9:1, the driveshaft only has to rotate 3.9 times for the wheels to rotate once. So if everything else remains the same, the engine driving the 3.9:1 diff will be rotating less at the same speed.
But Subaru don't always keep everything else the same and keep changing the gear ratio's on us.....
For example
OK a TZ and a V5 wont be listed on the same gear chart !
Differnet model years and model run differnet ratios
Also remeber that your tacho is just an indicator as to rpm, often they are out by a few hundred rpm
to get overall drive ratio multiply rear diff ratio by the selected gear ratio
This will show the relation of engine rpm verses wheel rpm
  • 6 years later...
