Cranking over engine..
Miller
Hey
Im just about ready to start my car for the first time in about 4 months..
It has a new turbo installed, and i want to crank over the engine for a while to get the oil circulating and through the turbo before I actually start the car..
Whats the best way to do this?
I dont want to flood the motor, so would the best way to be to pull out the fuel pump fuse? Or is there better ways?
Thanks in advance. :D
noooo dont do that!
first remove your crank angle sensor as this will stop it firing when turning it over.
then undo the turbo oil feed line off and put something under it to catch oil as you crank.
turn the car over till oil comes out the feed line - this will take longer than you think.
refit the oil line to the turbo and crank the car some more tilll turbo bearings are reasonably oiled. install crank sensor and fire car.
leave car to idle out for 15mins warm up and lube turbo.
this give or take is the install instructions from Garrett for one of their out of the box Ballbearing turbos. (what you have bolted on i have no idea but should hold true).
bear in mind also your battery might go flat with continued cranking so have some jumpers handy to help your battery out.
