ECU Pinouts
STiNGR
 JoKer said:
got no idea what so5 or 06 are but there are a few simple pinouts in the tech section / EBC instal guides etc
http://www.clubsub.org.nz/forum/index.php/topic,3081.msg38830.html#msg38830
Avc-R manual wiring in particular only really lists RPM/SPEED/injector etc
Its not for a boost controller. I dont know how to post a pic of a PDF if i could you guys would understand it alot more. Ive seen that possum link thing but still does not answer my question. Tried the search but no love.
Im trying to is wire in my Bee-r limiter. From the instructions in that link i think i have to use the S05 diagram BUT I dont have the 207 motor cos my car is not a sti I only have the 205 motor so Im abit confused which diagram to use. Im just not keen to go splicing and cutting the wrong wires and making a mess of my ECU wires. Are yous kinda following me...?
 JoKer said:
avcr does use speed wire therfore the speed wire is in the install manual
around page 40 or something like that (capped internets cant view files)
AVC-R are you talking about the boost controller? Its not a boost controller im trying to install.
cant at hm :/
56k speeds
pretty sure it uses all the same signal wires listed in the AVCr install manual / there is a pinout for Subaru/nissan toyota ECUs in the APEXI wiring diagrams for all / most ECU's pre 2000, which is what you are after no?
