wrx v5 clutch
victorjf
there's also MP Autoparts in the Hutt.
same thing, they'll do you a clutch to suit your needs and i believe they have factory replacement off the shelf for popular cars.
I got my clutch from them 3800lb iirc (pedal is lighter than my old factory one) and i think i paid bout $460 or there bout. i sent the old clutch to them on Wednesday and received the new one on Friday.
http://www.mpautoparts.co.nz/
0800 CLUTCH
 evowrx said:
FJK-7123 off the top if my head then HD for heavy duty. The cheapest option is to get one rebuilt through autoclutch and theyre far higher spec too. 3 day turn around on rebuilding yours.
Yep! Auto clutch far better than those excedy ones!
Get yours reco by neill and you WILL have a beaut clutch....Better than anything you maybe thinking of buying!
Just make sure you listen to his advice and fully understand how to setup when you install.
He Knows his stuff!!...Clutches are his livelihood!...For any clutch in any setup!
http://lmgtfy.com/?q=subaru+turbo+clutch+push+or+pull
only NA's use push so NO
http://www.subarugears.com/index_files/FAQ.html
Non-turbo TY752 transmissions used a push clutch which allows you to retain the VW cable clutch and pull the top of the clutch fork away from the engine. These are not suitable for turbo engines.
Turbo TY752 transmissions used a pull clutch which features a hydraulic slave cylinder to push the top of the clutch fork towards the engine.
Non-turbo TY754 transmissions produced from 1999 to 2004 generally used a push clutch with a hydraulic slave cylinder of a different design that pushes the top of the clutch fork away from the engine.
Turbo TY754 transmissions used a pull clutch with hydraulic slave cylinder like the turbo TY752.
TY755 and later from 2005 generally all used a push clutch for non-turbo and turbo applications. These featured a hydraulic slave cylinder to push the clutch fork away from the engine.
TY755 and later transmissions generally have a pop-out stub axle and cv joint as 1 piece. In order to use the Subaflange, a retrofit to the older ty752/ty754 circlipped stub axle and older seals is required. Please note this on your kit order and we can supply.
 victorjf said:
i found clutch exedy stage 2 more flywheel D1 ( 13lbs ) both per less than 800 dolares, but as i told, the guy said that is suitable o for models that have push clutch setups. WOULD IT FIT IM MY WRX V5?? if not maybe i will go for rebuilt
Who through? Tbh I wouldnt buy a clutch through someone who doesnt even know what theyre selling...
