New problems
D3ft0n3s
  • Replies 60
On the v7 it\'s on the drivers side collector area of the extractors just before the up pipe
U can see it if look down by the air box area or just get under car
The 02 wire plugs in the drivers strut tower with the other big plug
Ok so if they reflected then they can check code
V7 Ecu will not Cel and have no code
Get it scanned again
Get the code and start from there
If they changed o2 then was it the right model cos the v7 one is different to the gc8 one I u see the part numbers
Do a runnin scan and see if the o2 is reading right
At idle should be round the 14.47 mark and be going up and down around that number
Start there
Also is this a Nz new or import v7?
ok it\'s a gda
I\'m picking the guy has just got a wrx one not the proper one. if it is that what\'s the part number? oem and or one that works
can it do ecu damage?
thanks spoon your most helpful. do you still have your v7 ecu? car is import from Singapore
